How to hide dropdowns in panel header
Hey
I have asked this question on StackOverflow - https://stackoverflow.com/q/58832009/4495634
posting here to get some response as I didn’t get any on StackOverflow.
How can I hide/remove the dropdown which appears on hovering mouse on panels when viewing in kiosk mode. Below are the screenshots of dropdown which I want to hide.
I am working on a forked grafana with my custom panel plugins. I can remove it directly from the grafana code as I am working on forked grafana but I want to remove that only when viewing it from kiosk mode.
Right now I implemented that using post messages which I send to the iframe of grafana. This solution has lots of problems and I want to avoid it.
I also want this functionality. If I am in kiosk mode I don’t want the drop down hover.
If I look to the inspector from chrome the dropdown is caused by the panel-hover-highlight class.
But where is these class defined in the Grafana source code?
If you remove that class from thesource code then you can solve this.
Great question! Have there been any developments or discoveries WRT hiding dropdown headers in panels? We’re using the HTML plugin to put a series of buttons on a dashboard, however the buttons are hardly accessible due to the header hover in kiosk mode, which blocks users from clicking on the top half of the button.
Thanks!
