v7.5.4
What happened?
I am trying to push a notification having information of which query metric came back to [OK] state to a communication channel(say slack, MS teams) from an [Alerting] state.
I expected like in [Alerting] state, it has which query metric has gone into alerting state. When we go into the [OK] state we should be able to see which query metric is back to normal.
How can this be achieved?
Thanks you in advance ![]()
