Hey all,
So I am using github actions to use kubectl to apply a custom resource to kick off a k6 load test. My k6 test has a tag for testid that creates a unique guid. Is there anyway to get the testid so I can go to prometheus and see the data only for my test run?
thanks in advance
Hi @justinyoon1 !
Let me clarify some details.
Have you already defined the tag globally via Options reference | Grafana k6 documentation? So you just wonder how to get the generated value of the test ID?
Cheers!
