In my dashboard, I display a date in a timestamp format to see when an SSL Certificate will expire.
My first problem was that my values are displayed like that : “4047588” (it’s a timestamp in seconds that indicate that the certificate will expire in 6.69 weeks). To fix that, I selected the Unit “seconds” in standard options. Now it displays “6.69 weeks” which is fine.
To fine tune my dashboard, I want to force the time to be displayed in number of days instead of adapting of the value and display weeks.
Anyone have a suggestion ?
Thanks !
