Hello, we have default size for maximum message size
max_line_size: 128kb
and in exported metrics I see constant rate of:
loki_mutated_samples_total{reason="line_too_long"}
How can I find events with long lines?
I’ve read all the PromQL documentation and only came up with:
{cluster="eks-af-south-1"} |~".{1000,}"
which returns events >1k in size. But there are too many of such events, and it is the maximum regex value, so I cannot make it ".{100000,}" as it is the syntax error.
What are my options in searching for events which are getting truncated?
Thanks
