How to enable JWT Authentication for Grafana v8.5.22
    Grafana v8.5.22 setup on Linux
    Trying to enable JWT Authentication for accessing existing dashboards but configuration is not working
  1. Generated Public and Private keys at /etc/grafana directory with below commands
openssl genpkey -algorithm RSA -out private.key
openssl rsa -pubout -in private.key -out public.key
  1. Given required access to these 2 files with below commands following same ownership (root:grafana) as like other files in same directory /etc/grafana
chown root:grafana *.key
chmod 777 *.key
(Note: 777 only for temporary, I will change it later to 755)
  1. configured below details in /etc/grafana/grafana.ini
[auth.jwt]
enabled = true
header_name = X-JWT-Assertion
email_claim = sub
username_claim = sub
key_file = /etc/grafana/private.key
auto_sign_up = true
url_login = true
skip_org_role_sync = true
  1. restarted grafana with below command
    sudo service grafana-server restart
  2. generated JWT token with below python3 script
a) Install pyjwt module
pip install pyjwt
b) Python script to generate token as below ‘script.py’
import jwt
private_key = open(‘private.key’).read()
token = jwt.encode({‘exp’: 1681880400, ‘sub’: ‘existinguser@email.com’}, private_key, algorithm=‘RS256’)
print(token)
  1. Then used the jwt token with below URL for accessing existing dashboard (validated using incognito window)
http://grafana.staged-by-discourse.com/d/TPQDREZ/simple-streaming-example?orgId=1&kiosk&jwt=<JWT_Token>
  1. But it is redirecting me to login page with error status code 302 in logs at /var/log/grafana/grafana.log
    (Note: I have already enabled debug level and then collected logs)
logger=context traceID=000000000000000000000000000 userId=0 orgId=0 uname= t=2023-04-22T18:14:00.66-0500 lvl=info msg=“Request Completed” method=GET path=/d/TPQDREZ/simple-streaming-example status=302 remote_addr=127.0.0.1 time_ms=0 duration=164.93µs size=29 referer= traceID=000000000000000000000000000
  • What happened?
    Getting error status code 302 in debug logs at /var/log/grafana and URL getting redirected to login page.
    I’m expecting that grafana shows me a kiosk view page of dashboard when trying to use jwt token in URL
    I followed grafana documentation for setup which is not working for JWT Authentication.
I have grafana 10.1.2
In my grafana.ini is:
auto_sign_up = false
enable_login_token = true
and in the URL is .xxx.xxx:3000/?auth_token= and not &jwt=
I create my tokens with:
To do this, I read out the grafana.keys with an editor.
e.g. sudo nano /etc/grafana/grafana.key (raspberry pi)
Tip:
“iat” for the token can be created here:
:wink:
auth.jwt
allow_assign_grafana_admin = true
auto_sign_up=false
cache_ttl=60m
email_claim=sub
enable_login_token=true
enabled=true
expect_claims={}
header_name=X-JWT assertion
jwk_set_file=
jwk_set_url=
key_file=/etc/grafana/grafana.key.pub
role_attribute_path=
role_attribute_strict=false
skip_org_role_sync=false
url_login=true
username_claim=sub
What I forgot:
I created my grafana keys (raspberry pi) like this:
cd /etc/grafana/
sudo ssh-keygen -t rsa -b 4096 -m PEM -f grafana.key -N “”
sudo openssl rsa -in grafana.key -pubout -outform PEM -out grafana.key.pub
sudo systemctl restart grafana server
and
sudo nano /etc/grafana/grafana.key.pub
:slight_smile:
