How to customize the log severity at explore?
Hi there.
I’m using Grafana with Loki for my Kubernetes logging. At the ‘explore’ menu of Grafana, it shows the logs with pre-tagged severity (error, info, debug, etc). This works well most of the time, but I want to customize it a bit. For example, I got logs with the verbose level, but the Grafana doesn’t support it by default and showing it as unknown.
Is there a way to customize it? I looked up at the web but so far I didn’t find anything helpful.
Thank you.
Another thing is if grafana see in any place of the content log the word “severity”… then mark the log as “critical” and i dont want that
