Hi,I am using the promtail component for log collection,Examples of logs are as follows:
2023-08-30 10:14:56,274 INFO datanode.DataNode (BlockReceiver.java:run(1506)) - PacketResponder: BP-1986026358-172.18.0.29-1625995456331:blk_1102843442_29109253, type=HAS_DOWNSTREAM_IN_PIPELINE, downstreams=2:[172.18.2.29:1019, 172.18.0.31:1019] terminating
My promtail yaml config file is:
server:
http_listen_port: 9080
grpc_listen_port: 0
grpc_server_max_send_msg_size: 6291456
grpc_server_max_recv_msg_size: 6291456
positions:
filename: /opt/promtail/positions.yaml
clients:
- url: http://172.18.0.25:3100/loki/api/v1/push
batchsize: 4194304
scrape_configs:
- job_name: hdfs
static_configs:
- labels:
service: namenode
host: hdp001.datasw
__path__: /var/log/hadoop/*/*hdfs-namenode-*.log
- labels:
service: datanode
host: hdp001.datasw
__path__: /var/log/hadoop/*/*hdfs-*datanode-*.log
pipeline_stages:
- match:
selector: '{service=~"namenode|datanode"}'
stages:
- regex:
expression: '^(?P<time>\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2}),\S+ (?P<level>\S+) (?P<class>[\w.]+)'
- labels:
time:
level:
class:
- timestamp:
source: time
format: "2006-01-02 15:04:05 UTC"
- drop:
source: "level"
value: "DEBUG"
But when I first started promtail, all of logs were set the same timestamp,Is this normal? Or is there something wrong with my timestamp configuration?
