I’m new to Grafana and I try to create a stacked bar chart with Grafana as I do it in MS Excel with the Pivot function. I’m using an MS SQL Server.
But I don’t know how to get the Datum and MaschineName values to the x- axis.
Here are my values:
| Datum | MaschineName | Zustand | Dauer |
| 2023-02-06 | M1 | A | 1 |
| 2023-02-06 | M1 | B | 2 |
| 2023-02-06 | M1 | C | 3 |
| 2023-02-06 | M2 | A | 4 |
| 2023-02-06 | M2 | B | 5 |
| 2023-02-06 | M2 | C | 6 |
| 2023-02-07 | M1 | A | 11 |
| 2023-02-07 | M1 | B | 12 |
| 2023-02-07 | M1 | C | 13 |
| 2023-02-07 | M2 | A | 14 |
| 2023-02-07 | M2 | B | 15 |
| 2023-02-07 | M2 | C | 16 |
And my chart from Excel (that should also be the result with Grafana):
My SQL Code:
SELECT MaschineName, Zustand, Dauer, Datum as time FROM xxx
Thanks for your help
