Arch, version: 11.2.2, commit: c47b921ef40 -
I have an InfluxDB table that stores stats about my web server, specifically:
(timestamp, ms, path)
I would like to create a histogram that shows all paths separately. On top of that, I’d like to add all items over 100ms into one rightmost bucket.
I’m using the histogram visualization
I query the data asSELECT "ms" FROM "request_ms" WHERE $timeFilter GROUP BY "path"
I set the alias to $tag_path
I set the max value to 100
I set the unit to Time / ms -
What happened?
The histogram looks mostly ok
The histogram ignores any values over 100ms (and if I don’t, a single large value makes everything else illegilible)
The x axis uses the correct unit
The y axis uses the correct unit
The hover tooltips use millisecond for the counts. I see 3.03s when there are ~3030 instances of POST /api/v1/ping in the 0-10ms bucket
I expected everything over 100ms to go into the rightmost bucket
I expected to have the histogram count use numbers as the unit -
