I was following this link to test diameter protocol: GitHub - MATRIXXSoftware/xk6-diameter: A k6 extension for Diameter protocol
I was able to make it work for non TLS with TCP. I want to configure xk6 Diameter with DTLS using SCTP. Do we have any sample config or any help link which mentions all this in detail.
Hi @srikr,
I’d be happy to help you with any question or doubt you have regarding k6, but it looks like you’re trying to use a community extension (it seems to me that k6-diameter
isn’t really an extension that we officially support), so I think for this it’s better if you reach directly the maintainer through to the extension’s repository.
Thanks!
Sure Thanks. Will do that.
