I am using the latest version of the free Grafana Enteprise -
I am trying to display memory usage statistics provided from an InfluxDB OSS 2.7 bucket, generated by a telegraf agent running the docker input plugin -
Using the following Query:
fields = ["usage", ]
from(bucket: "MyBucket")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) =>
r.host == "${Host}" and
r._measurement == "docker_container_mem" and
contains(value: r.container_name, set:[${Containers:csv}]) and
contains(value: r._field, set:fields)
What happened?
The data appears as expected, but the graph is hard to read due to all the tags/attributes attached to the field names. Eg, instead of one set of data being named:
usage {container_name="MyContainer"}
it appears as
usage {com.docker.compose.config-hash="0ca69f9d7b39dacd8a57fb449181740e7bdd2f86ca17a0460b3caa49e4ccce19", com.docker.compose.container-number="1", com.docker.compose.oneoff="False", com.docker.compose.project="MyProject", com.docker.compose.service="MyService", com.docker.compose.version="1.24.1", container_image="MyImage", container_name="MyContainerName", container_status="running", container_version="unknown", engine_host="MyHost", host="MyHost", server_version="19.03.3"} -
I would like the legend and mouse-over tooltip to simply displayusage {container_name="MyContainer"}for each of the containers. -
Copied above. -
No -
No
