Ken
August 8, 2023, 10:46am
1
Hi, madam/sir,
As I remember, default timeout value in K6 for request is 60 seconds.
And I want to know how can I change this timeout value globally because some of my requests require more time to wait.
My requirement is that after I change it globally and all requests can use this new value.
Could you please help me?
Thanks,
Ken
Hi @Ken
Thanks for the question, you do remember it well.
While it is true that the default timeout is 60 seconds for k6/HTTP, there are some ways to work around it:
Having the option to set an HTTP timeout globally depends on the implementation of the new HTTP API . As you can check in the public roadmap , it is currently on the long-term list, and we have the epic issue to implement it as a k6 extension that could later become core k6.
I encourage you to follow Option to set default HTTP configuration globally · Issue #761 · grafana/k6 · GitHub and k6 extension: New experimental HTTP API · Issue #2461 · grafana/k6 · GitHub . And to help prioritize them.
Also note that if you use k6 browser , we already have an option to set the timeout: setDefaultTimeout(timeout) .
I hope this helps. Let us know if you still have questions or doubts.
Cheers!
Ken
August 9, 2023, 8:56am
5
Thank you so much eyeveebee, this really helps me a lot.
Thanks,
Ken
