For example: I want to make a button inside my panel, that changes the refresh-picker to ‘5s’.
I can see that RefreshPicker.tsx is extending PureComponent but I still don’t know how to use it…
Also: is it possible to change only one panel’s refresh rate?
If you’re referring to the refresh picker in the grafana/ui package, that’s only the UI control.
To update the refresh value itself, I think you could use the LocationSrv:
import { getLocationSrv } from '@grafana/runtime';
getLocationSrv().update({
query: {
'refresh': '5s',
partial: true,
replace: true,
davidm1
November 18, 2021, 9:09am
3
Thanks,
I’ve found this also in the docs recently but wasn’t 100% sure that this is the right way to do it.
It’s working fine.
Thank you
Can I know how to get the value of the same variable “refresh” value inside the plugin ?
I tried replaceVariables(‘$refresh’) but it doesn’t work.
Thanks in advance.
You mean get the current refresh-rate value?
I dont know. I tried to look in @grafana/runtime | Grafana Labs
but haven’t found anything yet
Yes exactly.
I didn’t find anything about this also.
system
Closed
December 9, 2022, 2:58pm
7
