Hello, I’m having a problem. When I set up alert rules in prometheus, I had a disk space monitoring rule that showed me the percentage of remaining space and humanize the value of the node_filesystem_avail_bytes metric.
Now my rule looks like this:
- alert: HostOutOfDiskSpace_test
expr: (node_filesystem_avail_bytes * 100) / node_filesystem_size_bytes > 0 and ON (instance, device, mountpoint) node_filesystem_readonly == 0 and {instance=~“10.22.22.18.*”}
for: 1s
labels:
severity: high
annotations:
summary: “Host {{ $labels.instance }} out of memory \n - Device: {{ $labels.device }} \n - Mountpoint - {{ $labels.mountpoint }}”
description: “Node memory is filling up. Value = {{ $value | printf%.2f}} ({{ printf "node_filesystem_avail_bytes{mountpoint=‘%s’, instance=‘%s’}" .Labels.mountpoint .Labels.instance | query | first | value | humanize1024 }})”
Here are examples of notifications from telegrams:
[PROBLEM] HostOutOfDiskSpace_test_1
Severity: high
Summary: Host 10.11.11.100:9100 out of memory
- Device: /dev/sda1
- Mountpoint - /boot
Description: Node memory is filling up. Value = 72.62 (736.4Mi)
Starts at: 2023-08-31 13:19:52.25 +0300 EAT
When I try to transfer this description to grafana, it outputs it as text.
[PROBLEM] Test_grafana_rules_filesystem
Severity: high
- Device: /dev/sda1
Description: Node memory is filling up. Value = 72.61% ({{ printf "node_filesystem_avail_bytes{mountpoint=‘%s’, instance=‘%s’}" .Labels.mountpoint .Labels.instance | query | first | value | humanize1024 }})
Starts at: 2023-08-31 13:22:49.12 +0300 EAT
My question is this. How can I display the actual values of the value of the node_filesystem_avail_bytes metric in description grafana?
