How the predict_linear working
Hi Guys,
I was able to use Prometheus predict_linear function to do the prediction for memory.
And I was able to set the time range to now-2d and now + 2d on Grafana.
However, as you can see the image I attached that in my predict linear function, I only predict what the next 6-hour memory would be.
I do not understand is that why the data keep exist for two days. It should not be any data after 6 hours right?
Thanks for your help.
I have same question, the data keep exist for two days in yours image because you set now + 2d. The chart display the next [v range-vector] in the predict_linear function, not the [t scalar].
