I send over metrics every 10 mins to get displayed on a grafana table panel. When I set the time to be the past 15 mins it displays the most recent metrics that got sent in the last batch.
When I set the time to be the past day however I can’t tell how it decides which metric gets to be the cell in the table. Based on what shows up in the cells it seems to be a mix of different metrics from different times throughout the chosen period.
In the raw table format I can see all the different metrics but when I group to a matrix it chooses one and I can’t figure out what it uses to do so. It seems random but I’m sure there’s some way it decides.
