hello.
I believe you are using an old version of the plugin. Try using the query Type as an Item tag instead of Application. Or if you don’t have the option, update your plugin version.
If you use Zabbix 5.4+ you must use itemtag, if it is version 5.0 or earlier, you must use application.
