How can I scrape content from dmesg
I wanted to send the kernel logs to Loki with Promtail, but haven’t figured out how to do it. Here is my attempt:
scrape_configs:
- job_name: kernel
  static_configs:
    - labels:
        job: kernel
        __path__: /dev/kmsg
But Promtail is giving out an error:
level=info ts=2024-02-25T18:11:00.07763986Z caller=promtail.go:133 msg="Reloading configuration file" md5sum=a809dbf068b9203bbe47c13d4223722a
level=info ts=2024-02-25T18:11:00.078824545Z caller=main.go:174 msg="Starting Promtail" version="(version=2.9.4, branch=HEAD, revision=f599ebc535)"
level=warn ts=2024-02-25T18:11:00.078929408Z caller=promtail.go:260 msg="disable watchConfig" reason="promtailServer cast fail"
level=info ts=2024-02-25T18:11:05.079104171Z caller=filetargetmanager.go:361 msg="Adding target" key="/dev/kmsg:{job=\"kernel\"}"
level=info ts=2024-02-25T18:11:05.079211544Z caller=filetarget.go:313 msg="watching new directory" directory=/dev
level=info ts=2024-02-25T18:11:05.079359504Z caller=tailer.go:145 component=tailer msg="tail routine: started" path=/dev/kmsg
ts=2024-02-25T18:11:05.079389133Z caller=log.go:168 level=info msg="Seeked /dev/kmsg - &{Offset:0 Whence:0}"
level=info ts=2024-02-25T18:11:05.079431812Z caller=tailer.go:163 component=tailer msg="tail routine: tail channel closed, stopping tailer" path=/dev/kmsg reason="seek /dev/kmsg: invalid argument"
level=info ts=2024-02-25T18:11:05.079476836Z caller=tailer.go:154 component=tailer msg="tail routine: exited" path=/dev/kmsg
level=info ts=2024-02-25T18:11:05.079489187Z caller=tailer.go:118 component=tailer msg="position timer: exited" path=/dev/kmsg
level=info ts=2024-02-25T18:11:15.080093129Z caller=tailer.go:206 component=tailer msg="skipping update of position for a file which does not currently exist" path=/dev/kmsg
level=info ts=2024-02-25T18:11:15.080286179Z caller=tailer.go:145 component=tailer msg="tail routine: started" path=/dev/kmsg
ts=2024-02-25T18:11:15.080342544Z caller=log.go:168 level=info msg="Seeked /dev/kmsg - &{Offset:0 Whence:0}"
level=info ts=2024-02-25T18:11:15.080399575Z caller=tailer.go:163 component=tailer msg="tail routine: tail channel closed, stopping tailer" path=/dev/kmsg reason="seek /dev/kmsg: invalid argument"
level=info ts=2024-02-25T18:11:15.080418681Z caller=tailer.go:154 component=tailer msg="tail routine: exited" path=/dev/kmsg
level=info ts=2024-02-25T18:11:15.080430076Z caller=tailer.go:118 component=tailer msg="position timer: exited" path=/dev/kmsg
Seems like the device file cannot be accessed by simply passing it as a static file. Is there any workaround for this? Thanks
I’ve never tried this before, so I could be wrong, but couple of things to try:
First make sure promtail is running as root. If that still doesn’t work, then it’s probably because /dev/kmsg being a device rather than a normail file that can be tailed. If that’s the case you can try one of two things:
  1. Kernel logs go through syslog (if i remember correctly). So you could change your syslog configuration and send kernel logs to a file too. I forgot the flag, but you should be able to find it in documentation.
  2. Rung dmesg periodically and output to a file then pick it up from promtail. This is probably less ideal.
Hi, sorry for the late reply. Debian 12 no longer have syslog and all the logs are going to the journald. I experienced a lot of other problems after this one so I decided to ditch Loki and installed GrayLog, which comes with FileBeat that can easily collect all logs from journald.
