How can I be alerted at specific times of the day?
Hi Folks,
For example, how can I set an alert to go off at 11am on weekdays, Japan time?
The data source is Prometheus.
I can get UTC hours and minutes with the hour() function minute() function, but I would like to know how to specify the time of day.
Thanks!!
@kos31de Did you manage to get any clue on that? I’m also struglling a lot to run my alerts during specific hours of the days. Don’t seem to be finding any option on the Grafana to run the alerts as per cron timings.
@pandeysumit887
I don’t know if this is what you are looking for, but I have set up my alerts as shown in this picture.
I think this is a redundant way to set it up and would like to know if there is a better way.
I hope this will be helpful.
for the hour and day transformation expressions i’m assuming they are the same as the minute transformation correct?
