I want to create a value map without case sensitive for exmple it shows check the log file when our value is error / ERROR .
How should define it ?
Hi @alex23
Can you share your query and some typical output results of that query?
my output is just :
error , warning , ora-
Is it currently case sensitive?
my output is sometimes error , ERROR
also sometimes show warning and sometimes WARNING
Best to use Regex option inside the value mapping
Value will be like this
(error|Error|ERROR)
and put the output you want to get e.g. “There is an Error”
I get that but my question is, is the value map configuration in grafana currently case sensitive?
