DashBoard A:
DashBoard B:
the B how to use the var “macid”
Can I define a template variable to receive it
thanks
DashBoard A:
In the link you must change ´´macid={__cell}´´ to ´´var-macid={__cell}´´.
As you said, you must define a variable ‘macid’ in dashboard B.
--------------------I solved it …
can i query with only the values which are provided in the URL in dashboard B
i dont understan you, could you explain?
how can i pass the dashboard A is time range to dashboard B through render link
