What Grafana version and what operating system are you using? Grafana v10.2.0-62263. Windows 11 Pro
What are you trying to achieve? Hovering over a PagerDuty annotation for more detail
How are you trying to achieve it? I’ve set up the PagerDuty datasource, have configured annotations for a service.
What happened? The annotations show on the graph, but when I hover over an annotation I get an error on the graph d.toLowerCase is not a function
What did you expect to happen? It would display incident details
Can you copy/paste the configuration(s) that you are having problems with? N/A
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. Yes, as written above. I have no further info. A network trace doesn’t show any details
Did you follow any online instructions? If so, what is the URL? Pagerduty plugin for Grafana | Grafana Labs
I also found a previous topic: Grafana panel crashes when hovering on a annotation
