High query latency in Loki
Hi everyone :waving_hand:
We are evaluating a migration from Fluent Bit + OpenSearch to Fluent Bit + Loki for several reasons.
Right now, we are testing Loki with a subset of our logs, around 50 GB/day, which is about 20% of what we store in OpenSearch.
Ingestion performance is very good and as expected.
The main issue is query latency, even with this limited dataset.
Example queries and response times [range 24h]
Query like:
sum(count_over_time({index_name="NAME"} | json [$__auto]))
Response time: > 1 minute
Unstructured query example (using a log field):
topk(10, sum by(log_request_path) (count_over_time({index_name="NAME"} |= `Optional Filter` | json [$__range])))
Response time: ~5 minutes
On OpenSearch, similar queries are almost instantaneous.
I understand Loki has different trade-offs, but I was expecting more acceptable query times for a dataset of this size.
Right now, I am the only one running queries. If we start creating dashboards and let development teams use Loki, the number of queries will increase fast, and performance might become a serious issue.
Setup and sizing
  • Data volume: ~50 GB/day
  • Storage: S3
  • Scaling: even with maximum scaling, Loki uses more than 2× the resources of our OpenSearch cluster
  • Performance: query speed does not improve with more resources
Component sizing:
Ingester:        2 replicas   1 CPU   2 Gi   (tot 2 CPU / 4 Gi)
Distributor:     2 replicas   0.5 CPU 0.25 Gi (tot 1 CPU / 0.5 Gi)
IndexGateway:    4 replicas   0.1 CPU 0.25 Gi (tot 0.4 CPU / 1 Gi)
Querier:         2 replicas   4 CPU   2 Gi   (tot 8 CPU / 4 Gi + autoscaling up to 50 replicas via KEDA)
QueryFrontend:   2 replicas   0.5 CPU 1 Gi   (tot 1 CPU / 2 Gi)
QueryScheduler:  2 replicas   0.1 CPU 0.12 Gi (tot 0.2 CPU / 0.25 Gi)
Compactor:       1 replica    0.5 CPU 0.5 Gi
ChunkCache:      8 replicas   0.5 CPU 16 Gi  (tot 4 CPU / 128 Gi - EBS 8×256 Gi)
ResultCache:     1 replica    0.5 CPU 1 Gi
Please note: even with this configuration, Loki uses more than double the resources of OpenSearch, but query performance does not improve.
Configuration:
analytics:
  reporting_enabled: false
auth_enabled: true
bloom_build:
  enabled: false
bloom_gateway:
  enabled: false
chunk_store_config:
  chunk_cache_config:
    background:
      writeback_buffer: 1000
      writeback_goroutines: 1
      writeback_size_limit: 500MB
    default_validity: 1h
    memcached:
      batch_size: 16
      parallelism: 24
    memcached_client:
      addresses: dnssrvnoa+_memcached-client._tcp.loki-chunks-cache.logging.svc
      consistent_hash: true
      max_idle_conns: 72
      timeout: 200ms
common:
  compactor_grpc_address: 'loki-compactor.logging.svc.cluster.local:9095'
  path_prefix: /var/loki
  replication_factor: 3
  storage:
    s3:
      bucketnames: bucket-logging-chunks
      insecure: false
      region: us-east-1
      s3forcepathstyle: false
compactor:
  delete_request_store: s3
  retention_enabled: true
distributor:
  ring:
    kvstore:
      store: memberlist
frontend:
  compress_responses: true
  log_queries_longer_than: 5s
  max_outstanding_per_tenant: 4096
  scheduler_address: loki-query-scheduler.logging.svc.cluster.local:9095
  tail_proxy_url: http://loki-querier.logging.svc.cluster.local:3100
frontend_worker:
index_gateway:
  mode: simple
ingester:
  autoforget_unhealthy: true
  lifecycler:
    final_sleep: 0s
    ring:
      heartbeat_timeout: 1m
      kvstore:
        store: memberlist
    unregister_on_shutdown: true
limits_config:
  discover_log_levels: false
  max_cache_freshness_per_query: 10m
  max_entries_limit_per_query: 100000
  query_timeout: 300s
  reject_old_samples: true
  retention_stream:
  - period: 2160h
    priority: 100
    selector: '{retention="90d"}'
  - period: 1440h
    priority: 90
    selector: '{retention="60d"}'
  - period: 720h
    priority: 80
    selector: '{retention="30d"}'
  - period: 336h
    priority: 70
    selector: '{retention="14d"}'
  - period: 168h
    priority: 60
    selector: '{retention="7d"}'
  - period: 168h
    priority: 60
    selector: '{retention="default"}'
  - period: 72h
    priority: 50
    selector: '{retention="3d"}'
  - period: 24h
    priority: 41
    selector: '{retention="2d"}'
  - period: 24h
    priority: 40
    selector: '{retention="1d"}'
  split_queries_by_interval: 1h
  volume_enabled: true
memberlist:
  dead_node_reclaim_time: 30s
  gossip_to_dead_nodes_time: 15s
  join_members:
  - loki-memberlist
  left_ingesters_timeout: 30s
pattern_ingester:
  enabled: false
querier:
  max_concurrent: 4
  multi_tenant_queries_enabled: true
  query_ingesters_within: 3h
query_range:
  align_queries_with_step: true
  cache_results: true
  results_cache:
    cache:
      background:
        writeback_buffer: 500000
        writeback_size_limit: 1GB
      default_validity: 12h
      memcached_client:
        addresses: dnssrvnoa+_memcached-client._tcp.loki-results-cache.logging.svc
        timeout: 2000ms
        update_interval: 1m
ruler:
  storage:
    s3:
      bucketnames: bucket-logging-ruler
      insecure: false
      region: us-east-1
    type: s3
  wal:
    dir: /var/loki/ruler-wal
runtime_config:
  file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
  configs:
    index:
      period: 24h
      prefix: loki_index_
    object_store: s3
    schema: v13
    store: tsdb
server:
  grpc_listen_port: 9095
  grpc_server_max_recv_msg_size: 104857600
  grpc_server_max_send_msg_size: 104857600
  http_listen_port: 3100
  http_server_read_timeout: 600s
  http_server_write_timeout: 600s
storage_config:
  bloom_shipper:
    working_directory: /var/loki/data/bloomshipper
  boltdb_shipper:
    index_gateway_client:
      server_address: dns+loki-index-gateway-headless.logging.svc.cluster.local:9095
  hedging:
    at: 250ms
    max_per_second: 20
    up_to: 3
  tsdb_shipper:
  use_thanos_objstore: false
tracing:
  enabled: false
ui:
  enabled: true
FluentBit Output
labels:
  - service_name=fluent-operator
  - cluster=eks-production
  - index_name=$index_name
  - namespace=$kubernetes['namespace_name']
  - retention=$retention
structuredMetadata:
  level: $level
  kube_pod_name: $kubernetes['pod_name']
  kube_pod_ip: $kubernetes['pod_ip']
  kube_host: $kubernetes['host']
  kube_container: $kubernetes['container_name']
  kube_app_kubernetes_io_name: $kubernetes['labels']['app.kubernetes.io/name']
  kube_app_kubernetes_io_instance: $kubernetes['labels']['app.kubernetes.io/instance']
  kube_app_kubernetes_io_component: $kubernetes['labels']['app.kubernetes.io/component']
  kube_app_kubernetes_io_part_of: $kubernetes['labels']['app.kubernetes.io/part-of']
removeKeys:
  - kubernetes
Has anyone faced similar performance issues with Loki?
Do you have suggestions on how to optimize query latency?
Thanks a lot for any advice
I think your first priority is to make sure query splitting actually works. You need to set either frontend_worker.frontend_address or frontend.downstream_url, see Query frontend example | Grafana Loki documentation.
There are a couple of other things:
  1. I noticed you are setting replication_factor to 3, but you only have two ingesters. You should either bring ingester to 3, or lower replication factor to 2. In general unless you are very worried about log being lost I’d say 2 is ok, since after some time your logs will be stored in S3 anyway.
  2. In general you want more but smaller queriers, not the other way around. I think it’s probably good to have each querier be allocated with 2cpu and 2GB memory, and scale more of them. You will probably need to run the cluster with a production load to determine what the best allocation is.
Firstly, you are comparing two different databases: one is indexed and the other is not. Therefore, the performance will be highly situational.
What I like is to do a query breakdown to see which parts are the slowest, as recommended in How to improve query performance in Grafana Loki . Then it’s easier to understand which component is bottlenecking it.
Also for us, the json parser is always the slowest part of a query, so we try to move as many fields to structured metadata to offload heavy lifting to index-gateway
Thanks! You are right about the replication_factor that was a mistake and I already fixed it.
About the query splitting, frontend_worker.frontend_address and frontend.downstream_url are not used because the system is running with QueryScheduler, which is the newer and more optimized setup for query splitting with the pull model.
QueryScheduler is very interesting because I use its metrics with Keda to scale the queriers based on the number of splits waiting in the queue.
That said, even in the limit case when everything scales to the max, cpu and memory were never a problem.
Thanks! I know the databases are different, and I don’t expect the same performance, but the use case is basically the same.
Most of the time, the goal is to search for errors in the last 24 hours to see if there was any issue — but this query takes quite a long time. So I’m worried that for longer time ranges it might become unusable.
Also, we need to build dashboards that show graphs like the number of errors over time, the number of specific actions done by the app, and similar metrics. Right now, I get this performance when I run a single query at a time, but when we start creating more complex dashboards that execute many queries at once, the system will probably become unusable.
About the bottleneck, I haven’t been able to clearly identify where it is. That’s why I opened this post, after reading the online guides and checking the metrics. I’m afraid the problem could be related to some misconfiguration on my side.
I could be wrong, but I am pretty sure you’d still need to configure frontend_worker.frontend_address regardless. I’d give it a try if you haven’t.
Also, try using logcli and run a query against your cluster, it’ll give you some data points that might be useful.
