Hide user and password values in basic authentication configuration - Promtail
Promtail Helm chart version: 6.11.2.
I define the env vars:
extraEnv:
  - name: LOKI_USERNAME
    valueFrom:
      secretKeyRef:
        key: USER
  - name: LOKI_PASSWORD
    valueFrom:
      secretKeyRef:
        key: PASSWORD
And then this setup doesn’t work (401 Unauthorized):
    config:
      clients:
        - url: https://loki-url/loki/api/v1/push
          basic_auth:
            username: $LOKI_USERNAME
            password: $LOKI_PASSWORD
In the configmap file I can see that the values are $LOKI_USERNAME and $LOKI_PASSWORD literali.
I use argocd to deploy so there is no way I can expose the credentials. Can anyone help me?
Maybe leverage a .env file or a environment variable? Or a secret in gitlab?
Have you set this in your values.yaml
extraArgs:
  - -config.expand-env
And then you should use ${} for the environment variables
clients:
  - basic_auth:
      password: ${LOKI_PASSWORD}
      username: ${LOKI_USERNAME}
