How to hide the column which does not have value in cells?
Hi @MetroN ,
Have you tried with Override - Hide in table ?
This will hide a column in table but you will still be able to use values from that column in data links.
Best regards,
ldrascic
This is not what I’m asking. I need to hide column only without the data.
What is your datasource and version of grafana
Also how do you define cells without data
Is it empty string null or ?
Data store is MSSQL. empty shell is defined as null.
This is more of mssql query than grafana issue
I would first off use a stored procedure for this if possible
Then using dynamic query hide the column wherein the sum of the column is null. Or you can use a temp table that to modify the final table schema
something like this using just mock data
declare @sql varchar(max) = 'SELECT SubCategory, ';
create table #grafana(
SubCategory varchar(50),
Opened int,
Closed int,
InProgress int
insert into #grafana
select 'Cheese Puffs', 0,1,null union
select 'Doritos', 0,1,null union
select 'Sambussa', 0,1,null
create table #summation(
Opened int,
Closed int,
InProgress int)
insert into #summation
select sum(Opened) as Opened,
sum(Closed) as Closed,
sum(InProgress) as InProgress
from #grafana
if not exists(select 1 from #summation where Opened is not null)
begin
--set @sql = concat(@sql, ' Opened ')
ALTER TABLE #grafana DROP COLUMN Opened
end
if not exists(select 1 from #summation where Closed is not null)
begin
--set @sql = concat(@sql, ', Closed ')
ALTER TABLE #grafana DROP COLUMN Closed
end
if not exists(select 1 from #summation where InProgress is not null)
begin
--set @sql = concat(@sql, ', InProgress ')
ALTER TABLE #grafana DROP COLUMN InProgress
end
--set @sql = concat(@sql, ' from #grafana ')
--exec(@sql)
select * from #grafana
drop table #summation
drop table #grafana
last column InProgress has all rows as null so it wont show up in table
