Hi all, I’m currently working on performance testing using k6 and facing an issue with request rates and failures.
I have a k6 script using the ramping-arrival-rate executor with the following stages:
startRate: 0
timeUnit: 1s
Stages:
(target: 5, duration: 30s)
(target: 1, duration: 30s)
The application under test is behind an Apigee proxy with a quota of 200 requests per minute (flexi quota type).
Ideally, I expect the test to generate 75 requests in stage 1, 150 in stage 2, and 90 in stage 3, totaling 315 requests. However, within the first minute of the test, requests exceed 245+ (instead of the expected 225), leading to 45+ failures due to the quota limit.
My questions:
How can I adjust the k6 configuration to better suit this use case and ensure a steady request rate?
Is there a way to use a constant request rate but still have stages?
Any workaround to fit my use case and prevent excessive failures?
Would appreciate any insights or suggestions!
