All,
I got the AWS ALB Ingress Controller setup in my AWS and I used Helm Stable charts for installing the Grafana in my EKS.
And now I am trying to enable the Ingress setups so that Grafana can be accessed within our network and here is the config file for it:
ingress:
enabled: true
annotations:
alb.ingress.kubernetes.io/scheme: internet-facing
kubernetes.io/ingress.class: alb
# alb.ingress.kubernetes.io/certificate-arn: arn:aws:iam::xxxxxxxxx:server-certificate/aws
alb.ingress.kubernetes.io/listen-ports: '[{"HTTP": 80}, {"HTTPS":443}]'
alb.ingress.kubernetes.io/actions.ssl-redirect: '{"Type": "redirect", "RedirectConfig": { "Protocol": "HTTPS", "Port": "443", "StatusCode": "HTTP_301"}}'
external-dns.alpha.kubernetes.io/hostname: grafana.company.com
service:
annotations:
alb.ingress.kubernetes.io/target-type: ip
labels: {}
path: /
hosts:
# - chart-example.local
## Extra paths to prepend to every host configuration. This is useful when working with annotation based services.
extraPaths: []
# - path: /*
# backend:
# serviceName: ssl-redirect
# servicePort: use-annotation
tls: []
# - secretName: chart-example-tls
# hosts:
Its creating the Load Balancer successfully. But its not creating the external DNS as I set in the annotations.
Any help here fellas…
Cheers!
Vikram
I solved the issue and whats the issue u r facing?
Hi Vikram,
Below is my values.yml file used to install grafana(latest) using helm(latest). I am running this inside AWS- EKS cluster and able to have the LoadBalancer created and working Grafana as expected.
persistence:
enabled: true
storageClassName: gp2
adminPassword: ReallyStrongpswd
service:
type: LoadBalancer
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
url: http://prometheus-server.mynamespace.svc.cluster.local
access: proxy
isDefault: true
However, now I want to make the LoadBalancer as HTTPS, I have a domain something.somerandom.io and cert created for that using AWS Cert Manager. I have the ARN for the Cert and the Domain as well.
So my question is there a way to just add the cert to the already created LoadBalancer IP by using the above values.yml?
I tried to do similar to what you did in this issue, but then I could not find any new alb created at all.
Hi Vikram,
I reached this page as im having a similar issue exposing the grafana service using aws alb.
You said “I solved the issue” . . . . which is great, for you.
Could you possibly provide some details to help others?
Even your final values.yaml setup would be really helpful
Thanks
hello there i just solved the issue and i figured it out from their helm chart…they have provided some flag that you can use to set you customise elb . i was using internet facing ingress so i just follow basic instruction for adding helm repo and upgrade it and then to install it i set three more flags.
helm install grafana grafana/grafana --namespace grafana --set persistence.storageClassName=“gp2” --set persistence.enabled=true --set adminPassword=‘EKS!sAWSome’ --set ingress.enabled=true --set ingress.ingressClassName=“internet-facing-ingress” --set ingress.hosts=“your host name”
and it workes.
Hi @vikramyerneni found this thread as i am facing the same issue. Would you mind to share how did you solve the problem? Thanks
