I am working with load tests for frontend using xk6-browser and facing issue to handle a link inside shadow dom. I can run same code from playwright but its not working with xk6. I am using Page object model and sharing code here:
export class Homepage {
constructor(page) {
this.page = page
this.verifyDeviceLink = page.locator('.messenger-web-component h4.title')
async verifyDeviceIfRequired(){
this.verifyDeviceLink.click();
await Promise.all([this.verifyDeviceLink.click()]);
and here we have code for test case.
const page = browser.newPage();
const loginpage = new Loginpage(page);
const homepage = new Homepage(page);
await loginpage.goto();
await loginpage.doLogin(" ", "");
await homepage.verifyDeviceIfRequired();
await Promise.all([page.waitForNavigation()]);
page.close();
Kindly help me with this issue.
Hi @mujamil90. Welcome to the forum.
Is there a specific reason you’re calling click as follows as it clicks on the element twice:
Also, we should put click and waitForNavigation in the same promise to prevent race conditions. Here’s an example:
constructor(page) {
this.page = page
async verifyDeviceIfRequired() {
return this.verifyDeviceLink.click;
await Promise.all([
page.waitForNavigation(),
homepage.verifyDeviceIfRequired(),
Thank you for letting me know this and I have made the changes. I am getting problem while clicking on “Device link” as it is in Shadow dom. I am getting below error.
ERRO[0035] Uncaught (in promise) clicking on “.messenger-web-component h4.title”: timed out after 30s executor=per-vu-iterations scenario=ui
Hi @mujamil90,
You’re welcome. Can you send an example HTML page snippet that contains this component that the script can’t find?
Thanks.
I have attached image for HTML code. Please have a look.
Hi @maideypl,
I’ve tried querying shadow DOM, and it seems to be working. If possible, we would like to help further by receiving a script and an HTML snippet from you in text form (instead of a screenshot) to try to reproduce and solve the issue.
Here’s a working example:
export default async function() {
page.setContent("<html><head><style></style></head><body>hello!</body></html>")
await page.evaluate(() => {
const shadowRoot = document.createElement('div');
shadowRoot.id = 'shadow-root';
shadowRoot.attachShadow({mode: 'open'});
shadowRoot.shadowRoot.innerHTML = '<p id="find">Shadow DOM</p>';
document.body.appendChild(shadowRoot);
const shadowEl = page.$("#find");
check(shadowEl, {
"shadow element exists": (e) => e !== null,
"shadow element text is correct": (e) => e.innerText() === "Shadow DOM",
page.close();
Thanks.
