I have below response and below 2 scenarios to be done:
Take “id” from response randomly and use it in next request
Take all "id"s in array and iterate through all in next request
“count”:4,
“results”:[
“companyDetails”:{
“id”:“123”,
“name”:“abc”,
“URL”:“www.abc1.com ”
“companyDetails”:{
“id”:“345”,
“name”:“def”,
“URL”:“www.abc2.com ”
“companyDetails”:{
“id”:“678”,
“name”:“ghi”,
“companyDetails”:{
“id”:“901”,
“name”:“jkl”,
Thanks
Yusuf
June 17, 2022, 12:50pm
2
Run this request in setup function. And return this request in setup.E.g.
export function setup() {
let operatorAuth = Load.auth(Roles.Operator);
let createResponse= http.post(
'htttp://test.com.cv',
JSON.stringify({
config: [
amount: 1000,
operation: "x",
headers: {
"Content-Type": "application/json",
return [
operatorAuth.json(),
createResponse.json(),
When return the response body you can take all ids.data[0] represents operatorAuth.json() , data[1] represents the createResponse.json();
export default function(data){
`${data[1].results.id[(totalVu * (exec.vu.iterationInInstance)) + (exec.vu.idInTest - 1)]}`
If u want only take the random id,you can use same format,because when u run parallel you will take error. ${data[1].results.id[(totalVu * (exec.vu.iterationInInstance)) + (exec.vu.idInTest - 1)]}
this take id in body per iteration.You can think this formula below;
${data[1].results.id[0]}
${data[1].results.id[1]}
${data[1].results.id[2]}
…until last index in the body
