gRPC streaming API
Hello , Can we get a better example for using gRPC streaming api without using sleep function in it ?
I would like the VU iteration to complete as soon the sever finishing the stream , Using Promise doesnt seem to work.
Referring to the example given in grpc-server-streaming.js
HI @rahulgouthamgs!
As I see, you can ommit the sleep, because the iteration will wait the end of the grpc stream, and completes as soon the server finishes the stream.
Hi @bandorko , I see the iteration terminates and cancels the stream if we remove the sleep. Would you be able to confirm this ?
I got some more time yesterday and had to return a promise to make it work which would resolve/reject based on the stream event handler callbacks. Also i had to switch to using default async function to be able to use the async/await pattern waiting for the stream results.
For me, if I remove the sleep, the iteration terminates just after the server sent all the messages it wanted.
@rahulgouthamgs :
This is my proto file:
syntax = "proto3";
package proto;
option go_package = "./;proto";
message GreetRequest {
    string name = 1;
message GreetResponse {
    string greeting = 1;
service GreetStreamingService {
    rpc GetGreetingStream(GreetRequest) returns (stream GreetResponse) {}
This is my test script.js:
import { Client, Stream } from 'k6/experimental/grpc';
const GRPC_ADDR = '127.0.0.1:10000';
const GRPC_PROTO_PATH = 'greetingStream.proto';
const client = new Client();
client.load([], GRPC_PROTO_PATH);
export default () => {
  if (__ITER == 0) {
    client.connect(GRPC_ADDR, { plaintext: true });
  const stream = new Stream(client, 'proto.GreetStreamingService/GetGreetingStream');
  stream.on('data', (resp) => {
    console.log('Greeting received, part:', resp.greeting);
  stream.on('error', (err) => {
    console.log('Stream Error: ' + JSON.stringify(err));
  stream.on('end', () => {
    client.close();
    console.log('All done');
  stream.write({name:"Balazs"});
  stream.end();
this is my streaming server:
package main
import (
	"fmt"
	"log"
	"net"
	"time"
	pb "grpctest/pkg/proto"
	"google.golang.org/grpc"
type server struct{}
func (s server) GetGreetingStream(req *pb.GreetRequest, srv pb.GreetStreamingService_GetGreetingStreamServer) error {
	log.Println("Get greetings")
	for i := 0; i < 10; i++ {
		resp := pb.GreetResponse{
			Greeting: fmt.Sprintf("Hello %s! %d.", req.Name, i),
		if err := srv.Send(&resp); err != nil {
			log.Println("error sending response")
			return err
		time.Sleep(1 * time.Second)
		fmt.Println("greetings sent")
	return nil
func main() {
	listener, err := net.Listen("tcp", "localhost:10000")
	if err != nil {
		panic("error building server: " + err.Error())
	s := grpc.NewServer()
	pb.RegisterGreetStreamingServiceServer(s, server{})
	log.Println("start server")
	if err := s.Serve(listener); err != nil {
And this is the ouptut:
https://asciinema.org/a/cCzl9xs1tSw1NUnu0X7CI52CP
hi @bandorko , in my case since i abstract out all the stream calls into different method , my default main method look pretty simple and i have wait for stream end event to trigger before returning the final result.
It looks something like this
connected = false
client = null
export default async function (data) {
let input = "some random input";
let response = await grpc_streaming_call(input);
grpc_streaming_call(input) {
 let output = []
 if (!connected)  {
   client.connect(url,param)
 return new Promise((resolve, reject) => {
  const stream = new Stream(client, uri, params);
   output.push(resp);
    reject(err)
   resolve(result);
  stream.write(input);
  stream.end();
This helps if i have to do additional calls based on the result from grpc response , @bandorko do you think this is the way to go or any other ways to do this better ?
