groupByNodes (in plural, as opposed to groupByNode) graphite function does not show up in the query editor (please see image)
Is there a plan to add it?
I just noticed this issue too. It looks like it should have been addressed here β https://github.com/grafana/grafana/issues/5612 and made available from v4.5.0 ( Release Notes for Grafana v4.5.1 ) but I donβt see groupByNodes function in Grafana Cloud. What do I do wrong?
Thanks @valkillmoar. Actually see it is supported in v6.7.2.
I looked for the gfunc.js on my installation, and found it - it showed up.
See here:
For anyone who might have faced this issue when using Grafana Cloud, here is the relevant GitHub issue to track β https://github.com/grafana/grafana/issues/24287 .
There is a workaround to make groupByNodes function appear β you just need to select an older version of Graphite (1.0.x) and then switch back to Graphite 1.1.x, β the groupByNodes function will magically appear after that.
