I have a client app that is sending json to an opensearch instance. Here’s the mapping that I am using:
"mappings": {
"properties": {
"@timestamp": {
"type" : "date", "format" : "yyyy-MM-dd HH:mm:ss.SSSSSSSSS"
"ItemStatusEvent": {
"properties": {
"itemId" : {"type" : "keyword"},
"itemStatus" : {"type" : "keyword"}
As you can see there can be several ItemStatusEvent for the same itemId over the time. I would like to create a Pie Chart using something like:
How should I modify my query in order to take the latest ItemStatusEvent per itemId ?
Any help will be greatly appreciated ![]()
Jean-Pierre
