I have run a load test to target single api within a group. At the end of test, when checking metrics in test summary report, noticed group_metric is not equal to http_req_duration eventhough there is only on api within group, no other code/logic wirtten other than this. PFB the report which we got after test completion. Observed one more point, group duraion is always high since which includes http_req_blocker time also. Please clarify is this behavior correct and shows the right value.
data_received..................: 8.0 kB 133 B/s
data_sent......................: 961 B 16 B/s
group_duration.................: avg=4.79ms p(50)=2.34ms p(75)=2.4ms p(90)=3.31ms p(95)=15.92ms p(99)=26.01ms min=2.22ms max=28.53ms
✓ { group:::MonitorEngine }....: avg=4.79ms p(50)=2.34ms p(75)=2.4ms p(90)=3.31ms p(95)=15.92ms p(99)=26.01ms min=2.22ms max=28.53ms
http_req_blocked...............: avg=2.28ms p(50)=271ns p(75)=320ns p(90)=510ns p(95)=12.56ms p(99)=22.62ms min=240ns max=25.13ms
http_req_connecting............: avg=178.44µs p(50)=0s p(75)=0s p(90)=0s p(95)=981.42µs p(99)=1.76ms min=0s max=1.96ms
✓ http_req_duration..............: avg=2.4ms p(50)=2.25ms p(75)=2.3ms p(90)=3.2ms p(95)=3.24ms p(99)=3.27ms min=2.1ms max=3.28ms
{ expected_response:true }...: avg=2.4ms p(50)=2.25ms p(75)=2.3ms p(90)=3.2ms p(95)=3.24ms p(99)=3.27ms min=2.1ms max=3.28ms
http_req_failed................: 0.00% ✓ 0 ✗ 11
http_req_receiving.............: avg=49.03µs p(50)=46.57µs p(75)=54.4µs p(90)=58.1µs p(95)=60µs p(99)=61.52µs min=38.89µs max=61.9µs
http_req_sending...............: avg=110.41µs p(50)=98.16µs p(75)=123.48µs p(90)=136.31µs p(95)=174.68µs p(99)=205.37µs min=72.78µs max=213.04µs
http_req_tls_handshaking.......: avg=644.47µs p(50)=0s p(75)=0s p(90)=0s p(95)=3.54ms p(99)=6.38ms min=0s max=7.08ms
http_req_waiting...............: avg=2.24ms p(50)=2.11ms p(75)=2.15ms p(90)=3.01ms p(95)=3.02ms p(99)=3.03ms min=1.98ms max=3.03ms
http_reqs......................: 11 0.183323/s
iteration_duration.............: avg=4.84ms p(50)=2.38ms p(75)=2.45ms p(90)=3.36ms p(95)=16ms p(99)=26.11ms min=2.26ms max=28.64ms
iterations.....................: 11 0.183323/s
vus............................: 0 min=0 max=0
vus_max........................: 1 min=1 max=1
