Graph x and y coordinates
How to make a graph from the coordinates seen in the image? The following SQL query is used: SELECT x as x, y as y FROM xy order by x;
You should specify a time column in the Query Editor or for raw queries:
be sure your query at minimum has ORDER BY time and a filter on the returned time range.
This is an example query:
SELECT
  $__timeGroup(time_date_time,'5m'),
  min(value_double),
  'min' as metric
FROM test_data
WHERE $__timeFilter(time_date_time)
GROUP BY time
ORDER BY time
For more details check the PostgreSQL, MySQL and SQL Server documentation
So if I understand it correct the graph panel is time dependent and it is not possible to show data which is not time dependent?
