Hi community,
I haven’t worked with Grafana since version six and now have an issue with my latest Grafana table.
- What is your Grafana version?
7.5.11 - Are you using Grafana Cloud or self-hosted Grafana?
self-hosted - List the datasource associated with the alert
Prometheus
7.5.11 -
I merge multiple Prometheus queries into one table panel (instant option checked). But not all values are present at the same time (issue resides in Prometheus due to federation). However I remember there was a function to display the value as “Last (Not Null)”. I cannot manage to find it. Is this not possible with the table panel or is the feature gone? -
Fill in missing values with the last value.
TY&BR
Chris.
