Grafana Tempo - Pusher failed to consume trace data
I just started my learning path with Grafana and its stack and for 3-4 days I’ve been unable to resolve the issue with my ingestor. I cannot make it see/join the ring. My network looks like this:
I have local docker network with 1 container each of : grafana, alloy, tempo, mimir, loki, pyroscope
2 containers of same web application that will generate all the metrics/logs/etc.
The error I get in my tempo logs in my docker container is
caller=rate_limited_logger.go:38 msg=“Pusher failed to consume trace data” err=“DoBatch: InstancesCount <=0”
I would highly appreciate some help and advices because I’m going insane at this point.
my tempo.yaml is
    target: all
    server:
         http_listen_port:3200
    distributor:
      receivers:
        otlp:
          protocols:
            grpc:
              endpoint: "0.0.0.0:4317"
            http:
              endpoint: "0.0.0.0:4318"
      log_received_spans:
        enabled: true
      ring:
        instance_addr:127.0.0.1
        kvstore:
          store:inmemory
    ingester:
      lifecycler:
        address: 127.0.0.1
          ring:
            kvstore:
              store: inmemory
            replication_factor: 1
    query_frontend:
      search:
        duration_slo: 5s
    storage:
      trace:
        backend: local
        wal:
          path: /var/tempo/wal
        local:
          path: /var/tempo/blocks
    stream_over_http_enabled: true
