- v9.1.6
- I want to be able to use variables in filter keys for queries
- Using variable replacement syntax in filter keys
What happened?
- No variables are replaced in filter keys
- Variables should be replaced in filter keys not just filter key values
Ultimate goal is to able to use variables in filter keys in a dynamic manner. For example: I want be able to do: ${agent_name}_status
and that filter key should be replaced with ma_status
if the chosen value for agent_name
Grafana variable is ma
in this case.
According to Unable to use variables in opentsdb query filter key · Issue #43258 · grafana/grafana · GitHub, this support may have already been added but trying with latest/v9.1.6, I am unable to do so. Is this possible today? If not, can this be a feature request?
