Grafana Loki How to Count unique Values without Limiting?
How all,
i used the search but could not get to an solution what i want.
I want to count how many unique users logged in in the last 24 hours.
I don’t want to count how many logins i had, only unique users.
I created the following Query:
count(
    sum by (Username) (
    count_over_time(
      {service_name=~"^[A-Za-z]{3}[abasd][cbasd]0[0-9]{2}.*"}
      |= "Host1"
      |= "App1"
      | pattern "<_>1234.Username=<Username>,"
      | pattern "<_>Common.Text=<text>,"
      | text=~"test.*"
      [$__range]
This Query works fine if i set the time range to 1hour but if i want to go higher, i get into a Loki timeout.
Is there any way i can optimize that or get it working?
That probably means your loki cluster can’t handle the query. Check the logs and see if you see any error messages in there.
How big is your cluster, and how much log do you have?
