Grafana dont gets my data
Hello everyone,
i created an Panel with my PostgresSQL Query.
The generated SQL:
But there is no data showing.
When i type the raw generated sql command in postgressql i get 3 sites of data.
Can somebody help me fix my problem?
The Type of “date” is a timestamp without time zone
Best regards
Try to add the WHERE using Macro: $__timeFilter
Regards,
Fadjar Tandabawana
