Is it possible to add alert created time (a.k.a. startsAt) into alert annotations? I looked at Templating labels and annotations but I couldn’t find anything on matching/calling alert created/startsAt time.
Explanation:
To clarify, I am adding picture of alert created time (red marked) from Grafana console:
Alert created time is saved as startsAt JSON object in alert message:
"receiver": "Webhooksite",
"status": "firing",
"alerts": [
"status": "firing",
"labels": {
"AlertID": "CPU_Cores:monitoringserver",
"Contact": "webhook",
"Severity": "Critical",
"alertname": "CPU_Cores",
"cpu": "cpu0",
"grafana_folder": "Dev",
"host": "monitoringserver"
"annotations": {
"DashboardURL": "http://192.168.101.131:3000/d/fkwAvHo4k/linux-hosts?orgId=1&var-datasource=test&var-Server=monitoringserver&viewPanel=2&from=now-12h&to=now",
"description": "On server monitoringserver cpu core cpu0 is above 91.0%.",
"summary": "CPU Core alert"
"startsAt": "2023-01-21T12:58:00+01:00",
"endsAt": "0001-01-01T00:00:00Z",
"generatorURL": "http://grafana.staged-by-discourse.com/alerting/grafana/gc34VtF4z/view?orgId=1",
"fingerprint": "1d42325aaab24ba9",
"silenceURL": "http://grafana.staged-by-discourse.com/alerting/silence/new?alertmanager=grafana&matcher=AlertID%3DCPU_Cores%3Amonitoringserver&matcher=Contact%3Dwebhook&matcher=Severity%3DCritical&matcher=alertname%3DCPU_Cores&matcher=cpu%3Dcpu0&matcher=grafana_folder%3DDev&matcher=host%3Dmonitoringserver",
"dashboardURL": "http://grafana.staged-by-discourse.com/d/WnRPNXuMz?orgId=1",
"panelURL": "http://grafana.staged-by-discourse.com/d/WnRPNXuMz?orgId=1&viewPanel=3",
"values": {
"alert": 1,
"reduced": 91.21044553335274,
"result": 91
"valueString": "[ var='reduced' labels={cpu=cpu0, host=monitoringserver} value=91.21044553335274 ], [ var='result' labels={cpu=cpu0, host=monitoringserver} value=91 ], [ var='alert' labels={cpu=cpu0, host=monitoringserver} value=1 ]"
"groupLabels": {
"__alert_rule_uid__": "gc34VtF4z",
"cpu": "cpu0",
"commonLabels": {
"cpu": "cpu0",
"commonAnnotations": {
"externalURL": "http://grafana.staged-by-discourse.com/",
"version": "1",
"groupKey": "{}/{Contact=\"webhook\"}:{AlertID=\"CPU_Cores:monitoringserver\", Contact=\"webhook\", Severity=\"Critical\", __alert_rule_uid__=\"gc34VtF4z\", alertname=\"CPU_Cores\", cpu=\"cpu0\", grafana_folder=\"Dev\", host=\"monitoringserver\"}",
"truncatedAlerts": 0,
"orgId": 1,
"title": "[FIRING:1] CPU_Cores CPU_Cores:monitoringserver webhook Critical gc34VtF4z cpu0 Dev monitoringserver ",
"state": "alerting",
"message": "**Firing**\n\nValue: alert=1, reduced=91.21044553335274result=91\nLabels:\n - alertname = CPU_Cores\n - AlertID = CPU_Cores:monitoringserver\n - Contact = webhook\n - Severity = Critical\n - cpu = cpu0\n - grafana_folder = Dev\n - host = monitoringserver\nAnnotations:\n - DashboardURL = http://192.168.101.131:3000/d/fkwAvHo4k/linux-hosts?orgId=1&var-datasource=test&var-Server=monitoringserver&viewPanel=2&from=now-12h&to=now\n - description = On server monitoringserver cpu core cpu0 is above 91.0%.\n - summary = CPU Core alert\nSource: http://grafana.staged-by-discourse.com/alerting/grafana/gc34VtF4z/view?orgId=1\nSilence: http://grafana.staged-by-discourse.com/alerting/silence/new?alertmanager=grafana&matcher=AlertID%3DCPU_Cores%3Amonitoringserver&matcher=Contact%3Dwebhook&matcher=Severity%3DCritical&matcher=alertname%3DCPU_Cores&matcher=cpu%3Dcpu0&matcher=grafana_folder%3DDev&matcher=host%3Dmonitoringserver\nDashboard: http://grafana.staged-by-discourse.com/d/WnRPNXuMz?orgId=1\nPanel: http://grafana.staged-by-discourse.com/d/WnRPNXuMz?orgId=1&viewPanel=3\n"
What I would like to do
I would like to use variable {{ $startsAt }} inside Annotation field “DashboardURL” so that when user receives alert message and clicks on DashboardURL link it opens specific dashboard in time range when alert happened (e.g. &from={{ $startsAt }}-30m&to={{ $startsAt }}+30m). I am looking for something like next code (doesn’t work):
http://192.168.101.131:3000/d/fkwAvHo4k/linux-hosts?orgId=1&var-datasource=test&var-Server={{ $values.result.Labels.host }}&viewPanel=2&from={{ $startsAt }}-30m&to={{ $startsAt }}+30m
This is how I would like that dashboard opens:
Is it possible to add alert created time (startsAt) into annotations? What is the proper syntax to call that variable?
Best regards,
ldrascic
