Hii there,
So I have been playing around with grafana reporting and Volkov lab’s Grafana HTTP API datasource was very simple and effective in configuring the reports.
Then again, i have been also played with using webhook (node-red) to collect alert details.
And in node-red i get more details than the details from grafana HTTP API datasource, whereas it is to be noted that not all the additional details are useful and needed.
But the silencing URL created automatically for every URL is useful in silencing reports, Hence if it is available in Grafana HTTP API data source, it is really appreciated.
So, is it already available ,because i cannot loacte the datapoint.
Is it a common request, that it is already under development and can be expected in next release?
Or else can you suggest some ways that it can be injected to Grafana HTTP API datasource at the equivalent timestamp.
Thanks
Grafana version - v 9.5.5
What is expected - To show generated silencing URL in Grafana HTTP API datasource.
What is happening - The field is missing.
What is needed - Suggestions or Answers.
