Grafana alerting math expression for multiple queries
Hi guys,
Grafana version: 8.4.3 (self-hosted)
Alerting: Unified alerting
Datasource: Prometheus:
What I’m trying to achieve is to detect (based on Prometheus data serie for my 3 queues) if one of them (or more) and which one(s) have no data for last 30 minutes.
Data is collected by Prometheus every 5 minutes.
So, I have 3 queries defined for an alert:
A: queue_count{queue=“pull”, status=~“E|F”}
B: queue_count{queue=“in”, status=~“E|F”}
C: queue_count{queue=“out”, status=~“E|F”}
Then I have 3 reduce expressions (Reduce, Sum)
D reduces A
E reduces B
F reduces C
According to Grafana’s documentation for Reduce used with Sum function:
“Sum returns the total of all values in the series. If series is of zero length, the sum will be 0”.
So my understanding is this one should return 0 if there are no series (no data). Or not ?
Asking because above returns “no data”.
Now I’m trying to create math expression (G) to trigger alert as described above.
Is it possible this way ? Or any way ?
Or maybe I need to take another approach ?
EDIT: Looks like it’s also related to : “how to return metric value 0 when this metric returns ‘no data’”.I know i can add OR on() vector(0) but this one removes labels from result…Any advices ?
Thanks in advance !
Ged
