After installing grafana agent notice high CPU and memory consumption on the instance. Instance getting hung. Please suggest the fix.
Top Command output:
┌──[root@we1o203420bbj]─[/root]
└──╼ $ top -c
top - 07:08:44 up 1:22, 1 user, load average: 1.58, 1.25, 1.18
Tasks: 203 total, 1 running, 202 sleeping, 0 stopped, 0 zombie
%Cpu(s): 65.3 us, 20.6 sy, 0.0 ni, 11.7 id, 1.2 wa, 0.8 hi, 0.3 si, 0.0 st
MiB Mem : 15473.7 total, 9438.5 free, 2125.8 used, 3909.4 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 12994.8 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
27328 root 20 0 2171544 245384 110924 S **153.2** 1.5 0:06.13 /usr/bin/grafana-agent -config.file=/etc/grafana-agent.yaml
Version numbers (grafana, prometheus, graphite, plugins, operating system, etc.):
└──╼ $ rpm -qa | grep grafana
grafana-agent-0.38.1-1.x86_64
└──╼ $ cat /etc/redhat-release
Red Hat Enterprise Linux release 8.7 (Ootpa)
Using below agent config:
└──╼ $ cat /etc/grafana-agent.yaml
Sample config for Grafana Agent
server:
log_level: warn
metrics:
global:
scrape*interval: 60s remote*write:
- url: https://xxxxx/mimir/api/v1/push
basic_auth:
username: "xxxxxxxxxxxxxxxx"
password: "XXXXXXXXXXXXXXXX"
wal*directory: '/var/lib/grafana-agent' configs: # Example Prometheus scrape configuration to scrape the agent itself for metrics. # This is not needed if the agent integration is enabled. # - name: agent # host*filter: false
# scrape*configs: # - job*name: agent
# static_configs:
# - targets: ['127.0.0.1:9090']
integrations:
agent:
enabled: true
node*exporter: enabled: true include*exporter*metrics: true disable*collectors:
- "mdadm"
# logs:
# configs:
# - name: default
# positions:
# filename: /tmp/grafanaagentpositions.yaml
# scrape_configs:
# - job_name: varlogs
# static_configs:
# - targets: [localhost]
# labels:
# job: messages
# **path**: /var/log/messages
# - job_name: otherlogs
# labels:
# job: otherlogs
# **path**: /var/log/*log
logs:
configs:
* name: default
positions:
filename: /tmp/positions.yaml
scrape_configs:
* job*name: loki-logs static*configs:
* targets: [localhost]
labels:
job: varlogs
**path**: /var/log/*logclients:
* url: xxxxxx/loki/api/v1/push
basic_auth:
username: "XXXXXXXXX"
password: "XXXXXXXXX"
