Hi all
I have installed grafana-agent in static mode in my EKS cluster. I need screape metrics from AWS CloudWatch andb push it into Prometheus. I use a simple config for grafana-agent to enable cloudwatch_exporter .
integrations:
cloudwatch_exporter:
enabled: true
role_arn: ['arn:aws:iam::123456789012:role/grafana-integration']
region: ['us-east-1']
But in logs I see errors:
level=error msg=“failed to reload config file” err=“error loading config file /etc/agent/agent.yaml: failed to unmarshal integration "cloudwatch_exporter": yaml: unmarshal errors:\n line 2: field role_arn not found\n line 4: field region not found”
Could you please provide me with configuration examples for this exporter? Thanks
