Today we are releasing Grafana 8.2.3 These patch releases include an important security fix for an issue that affects all Grafana versions from 8.0.0-beta1.
Grafana Cloud instances have already been patched, and an audit did not find any usage of this attack vector. Grafana Enterprise customers were provided with updated binaries under embargo.
CVE-2021-41174 Grafana XSS
Summary
CVSS Score: 6.9 Medium
CVSS:CVSS:3.0/AV:N/AC:H/PR:N/UI:R/S:C/C:L/I:H/A:N/E:U/RL:O/RC:R/CR:L/MAV:N/MAC:H/MPR:N/MUI:R/MS:C/MC:N/MI:H/MA:L
We received a security report to security@grafana.com on 2021-10-22 about an XSS vulnerability in Grafana. It was later identified as affecting Grafana versions from 8.0.0-beta1 to 8.2.2. CVE-2021-41174 has been assigned to this vulnerability.
Impact
If an attacker is able to convince a victim to visit a URL referencing a vulnerable page, arbitrary JavaScript content may be executed within the context of the victim’s browser.
The user visiting the malicious link must be unauthenticated and the link must be for a page that contains the login button in the menu bar.
There are two ways an unauthenticated user can open a page in Grafana that contains the login button:
- Anonymous authentication is enabled. This means all pages in Grafana would be open for the attack.
- The link is to an unauthenticated page. The following pages are vulnerable:
/dashboard-solo/snapshot/*/dashboard/snapshot/*/invite/:code
The URL has to be crafted to exploit AngularJS rendering and contain the interpolation binding for AngularJS expressions. AngularJS uses double curly braces for interpolation binding: {{ }}
An example of an expression would be: {{constructor.constructor(‘alert(1)’)()}}. This can be included in the URL like this:
https://play.grafana.org/dashboard/snapshot/{{constructor.constructor('alert(1)')()%7D%7D?orgId=1
When the user follows the link and the page renders, the login button will contain the original link with a query parameter to force a redirect to the login page. The URL is not validated and the AngularJS rendering engine will execute the JavaScript expression contained in the URL.
Attack audit
We can not guarantee that the below will identify all attacks, so if you find something using the audit process described below, you should consider doing a full assessment.
Through reverse proxy/load balancer logs
To determine if your Grafana installation has been exploited for this vulnerability, search through your reverse proxy/load balancer access logs for instances where the path contains {{ followed by something that would invoke JavaScript code. For example, this could be code that attempts to show a fake login page or to steal browser or session data. The OWASP cheat sheet has several examples of XSS attacks.
Through the Grafana Enterprise audit feature
If you enabled “Log web requests” in your configuration with router_logging = true, look for requests where path contains {{ followed by something that would invoke JavaScript code.
Patched versions
Release 8.2.3:
Solutions and mitigations
Download and install the appropriate patch for your version of Grafana.
Grafana Cloud instances have already been patched, and Grafana Enterprise customers were provided with updated binaries under embargo.
Workaround
If for some reason you cannot upgrade, you can use a reverse proxy or similar to block access to block the literal string {{ in the path.
Example of an Nginx rule to block the literal string {{:
location ~ \{\{ {
deny all;
Timeline and postmortem
Here is a detailed timeline starting from when we originally learned of the issue. All times in UTC.
- 2021-10-21 23:13: Security researcher sends the initial report about an XSS vulnerability.
- 2021-10-21 23:13: Confirmed to be reproducible in at least versions 8.0.5 and 8.2.2.
- 2021-10-22 02:02 MEDIUM severity declared.
- 2021-10-22 09:22: it is discovered that Grafana instances with anonymous auth turned on are vulnerable. This includes https://play.grafana.org/ .
- 2021-10-22 09:50: Anonymous access disabled for all instances on Grafana Cloud as a mitigation measure.
- 2021-10-22 11:15: Workaround deployed on Grafana Cloud that blocks malicious requests.
- 2021-10-22 12:35: Enabled anonymous access for instances on Grafana Cloud.
- 2021-10-22 12:51: All instances protected by the workaround. From this point forward, Grafana Cloud is no longer affected.
- 2021-10-22 14:05 Grafana Cloud instances updated with a fix.
- 2021-10-22 19:23 :Determination that no weekend work is needed as the issue is of MEDIUM severity and the root cause has been identified.
- 2021-10-25 14:13: Audit of Grafana Cloud concluded, no evidence of exploitation.
- 2021-10-27 12:00: Grafana Enterprise images released to customers under embargo.
- 2021-11-03 12:00: Public release.
Reporting security issues
If you think you have found a security vulnerability, please send a report to security@grafana.com. This address can be used for all of
Grafana Labs’ open source and commercial products (including but not limited to Grafana, Tempo, Loki, k6, Tanka, and Grafana Cloud, Grafana Enterprise, and grafana.com). We only accept vulnerability reports at this address. We would prefer that you encrypt your message to us using our PGP key. The key fingerprint is:
F988 7BEA 027A 049F AE8E 5CAA D125 8932 BE24 C5CA
The key is available from keyserver.ubuntu.com by searching for security@grafana.
Security announcements
We maintain a category on the community site named Security Announcements, where we will post a summary, remediation, and mitigation details for any patch containing security fixes. You can also subscribe to email updates to this category if you have a grafana.com account and sign in to the community site.
There is also a Security category on the Grafana blog and you can subscribe to updates from our Security Announcements RSS feed.
