10.2.3
Red Hat 7.9
Configuration SSO with Auth Proxy (Apache) and auth LDAP -
What happened?
When the users connect on my Grafana 10.2.3, the SSO still works but in the Administration Users and access, the origin is Auth Proxy since the update 10.2.3.
Before, in the 10.2.2, the origin of the user was LDAP.
I d’ont make any modification on my configuration Apache or my Grafana.ini between the update 10.2.2 to 10.2.3.
My LDAP configuration is OK and functional. I tested it successfully with many accounts. -
What is the reason for this modification?
Thanks for your answer !
Eric
