Hi ,
I am getting below error whenever I try to run test case
" ERRO[0021] GoError: The moduleSpecifier “K6 Load Test: <%= title %>” couldn’t be retrieved from the resolved url “K6 Load Test: <%= title %>”.
Hi ,
Hi @kanikas8080
Welcome to the community forum
I imagine you are trying to run GitHub - benc-uk/k6-reporter: Output K6 test run results as formatted & easy to read HTML reports.
Based on the error, you could be running the script on a laptop or server that cannot download the bundle K6 Load Test: <%= title %>.
Do you have access to K6 Load Test: <%= title %> from the workstation running the k6 test?
Try something like curl https://raw.githubusercontent.com/benc-uk/k6-reporter/main/dist/bundle.js
to check if it can reach the file.
You can always download the file locally and import it locally, as a workaround, if that is the issue.
Cheers!
