ERRO[0002] Failed to load resource: the server responded with a status of 422 () browser_source=network line_number=0 source=browser stacktrace="<nil>" url="https://xxxx/oauth/access_token"
INFO[0005] "Token status: credentials do not exist" source=browser-console-api
It seems from the error ("Token status: credentials do not exist") there is an issue on the website and it might expect you to set credentials. Since I can’t see the website or your script, I can’t tell you more at the moment
To expedite the resolution process, may I request for your assistance in providing a way for us to reproduce the problem? It would be helpful if you could create a sample HTML page and reproduce the problem locally, then share it with us. You can use our test site if it would be helpful. This will not only aid in resolving the problem but can also benefit other users who might be encountering similar issues.
