Sorry if this question has been asked before but I want to know if there is a simple/easy way to create a get request that accepts headers and query params in 2022?
From the k6 examples we only see an example of query-params without headers. For more context I have a json file with a list of users to login and obtain auth credentials. Then I make a get request but i need to pass in the auth creds and query params because they differ between users.
Hi @nazad23, welcome to the community forum
I guess you are referencing URLs with query parameters and HTTP Requests?
While this isn’t explicitly said, there is nothing stopping you combing the two as in:
import { URL } from 'https://jslib.k6.io/url/1.0.0/index.js';
import http from 'k6/http';
export default function () {
const url = new URL('https://httpbin.test.k6.io/get');
url.searchParams.append('utm_medium', 'organic');
url.searchParams.append('utm_source', 'test');
url.searchParams.append('multiple', ['foo', 'bar']);
const res = http.get(url.toString(), {headers: {"MyHeader": "value"}});
console.log(res.body);
"args": {
"multiple": "foo,bar",
"utm_medium": "organic",
"utm_source": "test"
"headers": {
"Host": "httpbin.test.k6.io",
"Myheader": "value",
"User-Agent": "k6/0.39.0 (https://k6.io/)",
"X-Forwarded-Host": "httpbin.test.k6.io",
"X-Scheme": "http"
"origin": "77.236.182.19",
"url": "http://httpbin.test.k6.io/get?utm_medium=organic&utm_source=test&multiple=foo%2Cbar"
Also, if you will have URLs with multiple query values I would recommend giving them a single name as that will help with aggregation and querying later on.
Hope this helps you!
